Its a simple yet exciting lamp carved out of 3,7mm (0,145669inch) thick plywood.
The Rocket Lamp is a nice projekt for kids and adults to carve and build together.
The desing is optimized to use DIN format plywood that you can get everywere.
(at least in Germany )
The author’s moral rights;
Bjarne Tondersen
David Wernette
