I attempted to make one with 1/8” up cut spiral but and had lots of tool marks. How did you get yours to come out so smooth?
Greg
I used a 1/8 "Ball Nose" bit and spent a fare amount of time sanding. I tried a "sanding mop" on a drill press but found that it could not reach the small areas in-between the ripples. Sanded a few finger nails down on those areas :) Good Luck!
Rick Ogg
Thanks, I am attempting to create one now. Any way to enlarge to 24" width?
Greg
I've added a link to the "General Information" section (above right) with the link to download the Fusion 360 file. You can download it in several formats and you should be able to adjust the scale to meet your needs. Good luck.
Rick Ogg
Greg
Rick Ogg
Greg
Rick Ogg
