Remake of "Balancing Wine Bottle Holder"
Bob Jewell
Bob Jewell
Honolulu, Hawaii
These can be made in all shapes:
The trick that I have found is that the base should be cut at 45 degrees and the hole 7 inches from the base
Kristin Smith
Is the hole centered 7" from the base or does it start 7" from the base?
Kristin Smith
Bob Jewell
the hole is 7 inches on centre from the base which is cut at 45 deg. The hole in these are 1.25 inch, which is big enough for most bottles other than champers.
Bob Jewell
Bryan K Barrett
Is the hole cut at a 45 deg. angle or 90 deg.
Bryan K Barrett
