Ready to Leave
10 opens
0 copies
Wayne Burger
Wayne Burger
Ever been worried about burning down your house because you or your wife forgot to switch off your/her hair straightening iron?
Here is a simple solution.
MDF Wood
MDF Wood (×2)
Dimensions: 12 in × 12 in, Thickness: 1/8 in
$5.98
$5.98
Get Carving - Base
Once you have your material, fire up your X-Carve and get going.
For step 1, insert your 6mm MDF, run at the recommended settings using a 60 degree V-bit.
This should take around 30 min.
Still Carving - Rails
The rails come next – use the 1/8th inch spiral bit to carve out the rails from the 16mm MDF board.
This should take another 30 min or so.
Sanding, Paint and Assembly
Give all parts a light sanding to remove any rough edges.
Paint to engraved areas, to add some depth and texture.
Glue on the side rails to the tray.
Once the glue has cured, one can do a final sanding and apply a clear sealant to the finished piece.
Hand it Over
Hand it over to the intended user (in this instance wife) and load it up with her EDC.
