Ranchers Birthday Gift
Marc Schaefermeyer
Marc Schaefermeyer
Know a Rancher who needs a birthday gift? Get their Brand and make a rustic wood inlay for them to display.
Plane the back of the pallet wood
This is to get the back side of the wood smooth.
Miter the edges to wrap the wood and hide the cut edges
Miter the edge of the wood to have a 45 angle to attach the edge to make it look like the wood just wraps around the edge and hides the clean cut edge.
I glued and pin nailed then clamped these in place.
Pre-drill and Key-hole the back prior to milling
I drilled a 3/4" hole on a 45 degree angle for a stand. I also drilled out two key-hole slots for it to hang on a wall.
Cut out the inset and inlay
Cut out the inset where the inlay will be placed and also cut out the inlay.
I made mine so that the inlay would protrude out from the surface of the pallet wood back.
Make a video of the process...
Here is a YouTube video of the process as well.
