Special Offer: Up to 17% off the new X-Carve Pro
Hurry! Offer ends on 05/28 (12 days left)
Call us: (312) 775-7009
Email: help@inventables.com
Poker Chips
62 opens
14 copies
6 comments
Zach Kaplan
Zach Kaplan from Inventables
Chicago, USA
I used the Easel curved text app and 2 color acrylic to make some poker chips.
Black on Bright White Laserable Acrylic Sheet
Dimensions: 8 in × 12 in, Thickness: 1/8 in, Thickness Tolerance: ± .005 in
$11.49
$11.49
Design your chips
The standard size for casino chips is 39mm in diameter. So first make a circle in Easel that is 39mm.
William Greenwald
how do I cut the circles after the engraving
William Greenwald
William Greenwald
how do I setup the machine to engrave the letters first and then cut the circles second is their two paths?
William Greenwald
Carlos Olvera
Easel now has 2 steps so you can cut with 2 different bits. Another option is to design the circles with the letters in one workpiece (at the bottom), duplicate it and on one erase the letters on the other the circles. Make sure you carve the letters first, then cut the circles.
Carlos Olvera
Zach Kaplan
It would also be faster to use V-Carving instead of 1/32" bit to do the letters. I did a sheet at a time to make it faster.
Zach Kaplan
chris kelsch
How did you avoid all the gross dust that makes the white look grey?
chris kelsch
Zach Kaplan
I used the vacuum, them a tooth brush, and then washed them.
Zach Kaplan
