Plywood Nightstand
227 opens
81 copies
Yves Becker
Yves Becker
This is a little plywood nightstand, that takes just one hour to carve. It is done frome a sheet of 12mm thick cherry plywood.
Carve
58 minutes
First carve out all the parts of the nightstand with your X Carve.
Sanding
Sand all the edges.
Glue it together
Glue all the parts together as shown on the picture. Clamp everything together and let it dry.
Reinforce the joints with dowels
On the top and the side pieces, mark out the holes as shown in the pictures. Drill 6mm holes and glue in the wood dowels, so that they still stand out a bit. Saw them down with a japanese handsaw and sand them flush.
Apply a finish
You can apply all sorts of finishes, such as wax or oils.
