Picture Frame with Bent Picture
1046 opens
313 copies
2 comments
Steve Carmichael
Steve Carmichael
Lawrenceville, USA
This picture frame is designed to be carved on one side of a board. The picture is bent and wedged between two grooves with thin clear acrylic. I used beach terms for a vacation picture, but you can customize the theme by changing the words. If you make one, I’d love to see it!
Clear Acrylic Sheet - Cast
Dimensions: 12 in × 24 in, Thickness: 1/16 in, Material Type: Cast
$8.99
$8.99
Prepare Wood Blank
Cut a wood blank that is .75" thick, 11.5" wide, and 7.25" tall. The frame is designed to be 10.5" wide, so the extra 1" width allows .5" of clamping space on each side. I used 1×8 pine, but any wood will do.
Clamp and Carve
Clamp the wood down to the wasteboard. Place clamps on left and right sides only. Keep clamps within .25" from the edges of the board to allow for bit clearance.
Install a 1/16" bit. Position the bit at the bottom left corner of the board and carve. Carve time is approximately 47 minutes. When finished carving, use a table saw to trim off the extra width that was used for clamping.
Sand and Finish
Sand any fuzzies off the carved surface. Apply paint or finish of your choice. Cut the picture and a piece of clear acrylic to 7.5" wide x 3.75" tall. Bend and wedge the acrylic and picture into the grooves.
Note: To remove the picture and acrylic, bend them to relieve the force from the edges of the grooves. If you pop out the ends, the acrylic can catch the edge and chip out the face of the wood.
Andy Hawkins
What size photo is this designed for?
Andy Hawkins
Steve Carmichael
You can change the design to fit any size. I thought I was going to have to measure it, but I see in step 3 that I said cut the picture and a piece of clear acrylic to 7.5" wide x 3.75" tall. Bend and wedge the acrylic and picture into the grooves. So 7.5" wide x 3.75" tall.
Steve Carmichael
