Picnic Plate
123 opens
39 copies
378 downloads 0 comments
Antonio Hernandez Menchaca
Mexico City, Mexico
This design allows you to take the essentials for a picnic in a single package. The package includes a main plate, cutlery and side plate for condiments, which join through rare earth magnets. Check Instructions for further explanation!
Bamboo Plywood
Bamboo Plywood (×2)
Thickness: 3/8 in., Plies: 7 ply, Dimensions: 12 in × 12 in
$36.98
Clear Acrylic Sheet - Cast
Dimensions: 12 in × 12 in, Thickness: 1/4 in, Material Type: Cast
$9.74
$46.72
Picnic_Plate.pdf
Description
Material
For this project you will need to following materials:
- 12 × 12 inch 3/8 inch Bamboo Plywood
- 8 × 8 inch 1/4 inch Clear Acrylic Sheet
- (12) 4 mm wide 2 mm deep rare earth magnets
- 150 grit sandpaper
Carving
55 minutes
Set and fasten your pieces and carve them. This should take about 55 mins without taking material change into consideration.
Chamfer Edges (Optional)
If you have a router with a roundover bit, rounder over the edges with curves on the bottom side of the plates.
Sanding
Sand all the edges down with your sandpaper until they’re nice and smooth.
Finish
Dip the bamboo plywood in mineral oil for a food safe finish.
