Phone Amplifier
1150 opens
348 copies
1366 downloads 2 comments
Beyond Design
Beyond Design
Chicago, Illinois
This phone stand uses corian profiles to create an acoustic amplifier. It can fit most phones and is easily adjustable.
Black Corian®
Black Corian®
Thickness: 1/2 in, Dimensions: 8 in × 12 in, Cut Tolerance: +/- 1/8 in
$76.54
White Corian®
White Corian®
Color: White, Cut Tolerance: +/- 1/2 in, Dimensions: 10 in × 12 in, Thickness: 1/4 in
$76.54
Phone amplifier layout.svg
Phone amplifier back panel.svg
Adjust depth for your phone/case
In Easel you can adjust the depth of the two profiles in the top right to control the thickness allowed for a phone. Right now each one is set to .1875" which makes it .375" overall. This is a good starting point, as it will fit pretty much any phone, as well as phones with slim cases.
Use this EASEL link
Mill the profiles
Mill the main profiles out of 1/4" material. Use a 1/16" bit for better results on the smaller features.
Mill the Back profile
Mill the back piece out of your choice of material. This part will not only provide an accent color, but will help reinforce the thin wall section around the phone slot. 1/2" Black corian provides a nice contrast to the front of the design.
Use this EASEL link
Assembly
Carefully glue and clamp the profiles together one at a time. Super glue is effective in adhering the corian together. Use a clamp or jig to ensure that the parts are neatly aligned to each other.
Ethan
666
Ethan
Andrew Freund
hey buddy, your doing really good so far. keep up the good work.
Andrew Freund
