Personalized Boxing Sign
196 opens
53 copies
583 downloads 0 comments
Chris Kerschner
Chris Kerschner
Make a custom boxing sign as a gift for that boxing fan or yourself. The burnt straight grained Douglas Fir gives the sign texture while accenting the engraving.
boxing badge.ai
Original Adobe Illustrator file
Preparing the Material
This project is made from Straight Grained Douglas Fir, but if you don’t have that available then any wood with a pronounced grain will work.
Gluing and Cutting the Board
The final dimensions for this project will be 16″×16″. You’re going to
  • Cut and trim your boards for gluing up. Make sure you cut them larger than the final size.
  • Glue up the boards and let them dry overnight.
  • Cut the glued up boards to the final dimension of 16″×16″ or whatever size you want.
Burn and Scrape the Wood
Burn the Wood
You’ll use one of those inexpensive propane torches to burn the wood. Don’t be shy with this part. The idea is to burn the softer wood in-between the rings.
Brass Brush Time
Moving with the grain, use a brass brush to remove the burnt areas. You should see raised areas as you remove the softer burnt parts.
Tip: When you’re trying to figure out how much to remove, just remember that the wood will be about 2 shades darker when you apply finish.
Softer Brush
Use a whisk brush or something similar to help get out the burnt dust.
[Optional] Burnishing
Burnishing is where you compress the fibers of wood by sliding the end grain of another piece of wood on to it. If you have any questions please take a look at the video at the end.
Carving
Settings
  • Material – Event though the wood is softer I used the default rate for Birch
  • 1/16" 1F Spiral Upcutting Bit
  • 1/8" Depth
Note: You can mess with the feed settings and depth per pass but remember Douglas Fir is a brittle wood and will chip out a lot if you are really aggressive. It’s best to create a couple of test samples instead of guessing on your final board.
Protective Finish
In my project I used some spray water based satin polyurethane. This sprays on a milky white color and dries clear.
Just be aware if you use the oil based polyurethane it will add a yellowish color to the project and darken it more than the water based stuff.
Once the finish dries just add some hanging hardware and you’re good to go!
Suplimental Video
This is a video showing how I made the project and how I fixed some of the mistakes that came up.
