Special Offer: Up to 25% off the new X-Carve Pro
Hurry! Offer ends on 03/31 (27 days left)
Call us: (312) 775-7009
Email: help@inventables.com
Mon - Fri: 9am - 5pm CST
Pencil Box and Stand
672 opens
200 copies
2 comments
Beyond Design
Beyond Design
Chicago, Illinois
A simple pencil box and matching stand to hold your favorite pens. We used a white corian base to contrast a walnut top, making these elegant desktop accessories.
6" × 12" × 3/4" Walnut
$7.99
6" × 12" × 1/8" Walnut
$5.57
White Corian®
White Corian®
Color: White, Dimensions: 10 in × 12 in, Thickness: 1/2 in, Cut Tolerance: +/- 1/2 in
$13.56
Mill Base parts
Mill the base of the pencil box and pen stand out of a sheet of corian. This is the longest cut of the project and will take several hours.
Use this EASEL link
Mill top parts
Mill the top of the pen stand. Make sure to double check the tolerances of the parts you already cut for a proper fit. This is also a good point to customize the holes in the pen stand to fit your favorite type of pen!
Use this EASEL link
Mill the lid for the pencil box
This part you can either cut from the 3/4in walnut if you have the patience, or you can get an eighth inch sheet that matches in color.
Use this EASEL link
Finishing and Assembly
These parts may take a bit of sanding to get a proper fit and finish. After sanding finish with your choice of oil and assemble the parts. If you kept the tolerances tight like we did you can get a friction fit, otherwise you can glue the pieces together.
Bartlomiej Kegor
Excellent pencil box!
Bartlomiej Kegor
David Skinlo
How do you create the tabs on the circumferential cuts?
David Skinlo
