Carved a sign for a buddy of mine. Used a “metallic” spray paint aka get glitter everywhere spray paint. Sprayed a thick coat over everything then wiped off as much as I could while still wet. This is my second carve turned out pretty good considering bit broke mid way.
The author’s moral rights;
