Night Light Duo
13 opens
1 copy
415 downloads 0 comments
Teams  Design
Teams Design
These friendly creatures will help you feel safe at night.
Bamboo Plywood
Bamboo Plywood
Thickness: 3/4 in - don't use, Plies: 3 - don't use 1, Dimensions: 8 in × 12 in - don't use 1
Hi-Lo Screw
Hi-Lo Screw
Thread Size: #10-26, Length: 1.00 in, Finish: Zinc Plated, Quantity: 10
Red on Bright White Laserable Acrylic Sheet
Dimensions: 8 in × 12 in, Thickness: 1/8 in, Thickness Tolerance: ± .005 in
$16.49
$16.49
NightLight_Frame_rev2.svg
NightLight_Cap_rev2.svg
Purchase USB cable and LED light
You will need these parts in addition to the materials from Inventables to complete this project.
USB Cable
LED Light
Cut out the Frame
Load this Easel link to cut out the Frame using an 1/8" bit.
Cut out the Cap
Load this Easel link to cut out the Cap using a 1/16" bit.
Tip: You can use materials of various thickness for this part as long as you adjust the thickness in the Easel file. So feel free to experiment!
Remove the parts
Separate the parts, and sand them down as needed.
Assemble the Frame
Insert the USB cord in the slot and assemble the frame.
Snap the Cap in
Depending on the tolerance, the Frame should hold the Cap in by friction. If not, you can use adhesive.
Plug it in
Insert the LED light in the USB port, and plug the other end of the cable in your spare phone charger.
Tip: You can make a paper cut out to cover the hole in the back for a more even diffusing of the light.
