Night lamp
16 opens
7 copies
karel desplenter
karel desplenter
This lamp is designed for beside your bed.
when your done reading your book you leave it ontop of the lamp, so you will hold your page.
Birch Plywood
Birch Plywood
Clear Acrylic Sheet - Cast
Dimensions: 12 in × 24 in, Thickness: 1/8 in, Material Type: Extruded
Light Diffuser Film Rolls
Dimensions: 12 in × 36 in, Thickness: .005 in, Surface: Matte on both sides
the cnc procces
55 minutes
according to fussion 360 the cutting procces only takes 55 min
this is done whit the 1/8 inch cutting bit
assembely
40 minutes
this procces is estimatedto be 40 min
finnising
the idea is to ad a led strip to the wooden dowel.
the wooden dowel has a diameter of 28mm and a lengt of 30 cm.
