Here are a few photos of my recently completed build of an expanded Shapeoko 2. I placed the electronics in a box with a clear cover, ran all of the cables from the motors to the box and placed the power supplies on a shelf under the CNC. My X-axis is 1500mm, Y is 600mm and Z is the standard size.
The author’s moral rights;
Charley Thomas
