Damon John Hoxworth Ventura, USA
SVG cut files for MeArm Robotics Arm for use with Arduino etc. https://www.mearm.com/
Original cut file was for a laser cutter. I offset the path (.0312) to account for my .0625 (1/8") 5.2mm plywood
Will try to update as I get the time to build this.
