X-Carve is in stock. Ships same business day Call us: (312) 775-7009
(M–F 9am – 6pm CST)
Master Wiring Kit
Bart Dring
Bart Dring from Inventables
This is a kit of all my favorite wiring products. This will allow you give your machine a professional look and add reliability.
Black Expandable Sleeving
Black Expandable Sleeving (×5)
Type: Expandable Sleeving, Color: Black, Range: 1/8 in - 7/16 in, Size: 1/4 in
$7.45
Black Heat Shrink Tubing
Black Heat Shrink Tubing (×5)
Type: Heat Shrink Tubing, Size: 1/2 in, Ratio: 2:1, Color: Black
$9.95
Crimping Tool
Crimping Tool
Type: Plier, Plier Type: Crimping
$22.00
Drag Chain
Drag Chain
Type: Drag Chain, Inside Height: 15mm, Inside Width: 20mm, Qty: 1m, Link Type: Semi Open
Drag Chain
Drag Chain
Type: Drag Chain Ends, Inside Height: 15mm, Inside Width: 20mm, Qty: 2, Link Type: Semi Open
Ferrule Crimper
Ferrule Crimper
Type: Ferrule Crimper, Ferrule Range: #26-#10, Jaws: 4
Flush Cut Pliers
Flush Cut Pliers
Type: Plier, Plier Type: Diagonal
$4.99
Header Wiring Kit
Header Wiring Kit
Type: Kit
Insulated Ferrule Kit
Type: Ferrule Kit
$24.99
Molex Microfit Connector Ultimate Kit
Type: Kit
$69.38
Scott Daniels
Question routing the wiring on my Hadron but struggling with crimping the Microfit connectors. Using the SN-28B but the jaws are too wide and crush part of the end of the pin (male) so that it will not latch into the plastic shell... do you get this crimp tool to work w/ Microfit? -Thnx
Scott Daniels
