Marble Game
604 opens
238 copies
1 comment
Sam Alaimo
Sam Alaimo
Get all the marbles to the middle. This game is surprisingly harder than it looks! The slick design makes in a nice addition to a home or office.
Cherry Wood
Cherry Wood
6" × 12" × 1/2" Cherry Wood
$8.86
Clear Acrylic Sheet - Cast
Dimensions: 8 in × 12 in, Thickness: 1/16 in, Material Type: Cast
$2.99
$11.85
Carve the wood
Open the project and carve the Workpiece labeled “wood base”. Any 1/2 wood or material should work.
Carve the acrylic
Next, go to the Workpiece labeled “acrylic cover”. Cut this out of any 1/16" thick acrylic.
Add the bearings
I used 5/32 inch Diameter Chrome Steel Bearing Balls for the balls in this game.
Put the acrylic in
I was able to press fit the acrylic into the wood (I used the inlay app to get the measurements right). I didn’t use any glue, and the top stays in nicely unless you bang in upside down on a table.
You can glue it if you would like!
Steve Kinnaird
The outer edge and the maze walls are the same height. This will not allow the 1/16" overlay to fit in the channel. It rests on the maze walls.
Steve Kinnaird
