Make a Wall Mounted Tool Rack
52 opens
13 copies
727 downloads 2 comments
TheArtofWeapons
TheArtofWeapons
In this tutorial I an going to show you how to make a wall mounted tool rack for the X-Carve. It’s a simple project and is perfect for a first carve or just testing out the machine!
MDF Wood
MDF Wood
Dimensions: 5.75 in × 5.75 in, Thickness: 3/4 in, Type: MDF
Tool Rack (1).nc
G-code file
Select Tools and Design Layout
So the first step is do decide on your tool layout. If you are lazy like me and have the same tools that came with the x-carve then you can just skip this step and use my tool rack files.
Once you have decided on what tools to use and the layout then you can go on to designing them on any CAD program that can save as an SVG to be imported into easel or simply just create the shapes in easel with a bit of improvisation!
Carve!
300 minutes
Once in easel, select the appropriate material (for me it was pine wood), then select the feeds and speeds and the spindle bit you are using.
Then send it to carve and wait!
Depending on the bit size and the material this can take up to 6 hours!
Paint
If you want you can paint your tool rack, I opted for black and then sanded the surface back to the wood grain to reveal a cool contrast in the carved areas
Wall Mount
Then you are done!
Its as simple as a few rawl plugs and screws and your awesome tool rack is complete!
https://www.youtube.com/watch?v=Ktay2yUMnIA
Good luck!
David Miles
It can't be opened in Easel because it says "This project has not been shared publicly". Can you fix this please?
David Miles
Andrew Kowtko
Can you please share this file publicly? Thank you.
Andrew Kowtko
