karl christie
Decorative shield featuring hand drawn designs. The final shield is created by two types if wood that creates a color contrast between the shield and the crest. The lion design was brought in the shield by using easels image trace feature
6" × 12" × 1/2" Walnut
12 minutes
carve the outline for the shield out of walnut
48 minutes
Carve the inner crest and design out of soft maple
using wood glue attach the crest to the shield base making sure it is centered. Then display with pride
