A LED sign made using Lucite Light Guide Acrylic Sheet 8×12×1/4 and Powered LED Strip from the Inventables website. Import your image into Easel and carve. I made a wood holder for light strip and sign.
The author’s moral rights;
Kenneth Maddux
Robert Justison
