This tile shows the basic concept behind using dogbone corners and the project goes through the steps of using the dogbone generator in the Apps tab in Easel. 2 pockets are carved in the surface so you can see how the removable dog tile fits with and without the removable dogbone corners.
The author’s moral rights;
Lorenzo Cruz
