Laser Modules are available from many distributors.
My go too’s are: ( you get what you pay for )
FWI: Most laser modules require a laser drive / control board to regulate and provide TTL control for the laser. The laser modules from OptLasers has everything that is required to drive the laser contained in the laserhead, and protected from dust.
My GRBL firmware fork & settings are posted @ AustinSaintAubin/grbl (GitHub)
Also See: jtechphotonics.com
That’s it for this step, not we need to convert your g-code.
You need modify the g-code from easel to make it work with the laser.
We are going to convert the 3-Axis CNC Router G-code generated from Easel, and turn it into G-code suitable for 2-Axis CNC Laser Engraving.
Once you have your Laser Mounted & GRBL Configured (see below if you have not) you are now ready to Laser Engrave.
You have a few options to run your converted gcode.
Austin St. Aubin
Joseph Bridgford
Austin St. Aubin
Steven Vasquez
Austin St. Aubin
Steven Vasquez
Patrick Rogers
Patrick Rogers
cristopher coleman
cristopher coleman
cristopher coleman
Austin St. Aubin
Kiko Lobo
Jeffrey Palacios
Austin St. Aubin
Pierre Fransson
Pierre Fransson
Tomas Bagdonas
Austin St. Aubin
Austin St. Aubin
Tomas Bagdonas
Austin St. Aubin
Samerson Marques
Samerson Marques
BritXpat USA
Austin St. Aubin
Michael Kunz
Austin St. Aubin
BritXpat USA
Wendy Carter
Austin St. Aubin
Wendy Carter
