X-CARVE IS ESTIMATED TO SHIP IN 10 - 14 BUSINESS DAYS.
COVID-19 Update: Inventables is fully operational. Call us: (312) 775-7009
(M–F 9am – 5pm CST)
Laser Cut Snowflake Ornaments
Astrida Valigorsky
Astrida Valigorsky
A couple of great snowflake ornaments made from Radiant Acrylic! These look amazing on a tree or any dark background. Made with an Epilog 35 Watt lasercutter, however it would be possible to make them with a shapeoko.
Files to make this project are available here for non-commercial use.
Radiant Acrylic
Radiant Acrylic
File type blank
Astrida_flakes.eps
EPS File
File type blank
Astrida_flakes.dxf
DXF File
File type blank
Astrida_flakes.pdf
PDF File
1. Do you have a lasercutter? Or a shapeoko?
Note what the device type you’re going to cut this on IS.
2. Obtain the proper file for your device from the Author
Files are posted here, but if you need something a little different for the machine you’ll cut things on, you’re welcome to email the author for modifications.
3. Make Your Cuts
The file size of the document sent is based on the smallest size material here (8×12 plexi). There are 8 snowflakes of varying sizes in the file. You may need to modify it before you make your cuts if you have more material.
4. Hang your Ornaments
The design of the ornaments has small holes to thread wire or nylon thread hangers through it.
