An art deco style reindeer ornament with a aboriginal design detail. Made in gold or bronze acrylic that is cut and etched with a laser cutter. Will also work on a shapeoko if you convert it & have the right bits for acrylic. You only need one of the acrylic sheets listed here to make 8 deer.
The author’s moral rights;
Paul Kaplan
Astrida Valigorsky
Zach Kaplan
