Support closed Sunday 4/2
Knock-Down 30" Stool by Le PicBois
368 opens
146 copies
619 downloads 0 comments
Pat Lap
Pat Lap
Shawinigan, Canada
I decided to test the capacity of my new X-Carve by drawing a 30 inches knock-down stool. This is the project file. Feel free to modify it as you want. Enjoy!
LePicBois_Knockdown_Stool_Illustrator.ai
Illustrator File
LePicBois_Knockdown_Stool_SVG.svg
SVG File
LePicBois_Knockdown_Stool_PrintablePlan.pdf
Printable Plan
Dimensions
Watch the Video!
- This video shows you the making process!
- Enjoy! Please leave a Comment and Subscribe!
- http://www.lepicbois.net/subscribe
Design in Adobe Illustrator
- Make your design in Illustrator on a 30" X 30" canvas.
- Then export a .SVG file.
*Note: You don’t need to make this step as I did it for you!
Open the file in Easel
- Import the .SVG file into Easel.
- Make sure you enter the correct dimensions of the project which is 30" X 30" X 0.75".
- Set the cutting depth at ¾" for the whole design except for the tabs on the seat. (those needs to be set to ½" deep.)
*Note: You don’t need to make this step as I also made it for you as well!
Just put a 30" X 30" X ¾" material on the machine and carve it!
Make your Blank
- Take a piece of plywood ¾" thick, and measure a 30″ × 30″ square.
(you can use MDF or laminated wood also)
Cut your Blank
- Now it’s time to cut your blank. I did 31″ × 31″ on mine just in case but you don’t need to. The design is made to fit a 30″ × 30″ blank.
Install the Blank on the X-Carve
- Install and secure the blank on the X-Carve. I screwed my blank directly on the wasteboard, but if you don’t want to damage it, just use clamps provided with the machine.
Carve the Design
120 minutes
- The longest part of the process is to wait for the machine to do its job. But it’s worth it!
- It took me about 2 hours to carve this design with the original parameters. You may be able to save a few minutes by changing the settings.
Wait for it...
- Stay close to the machine during the process to make sure there are no pitfalls or mechanical breakage. (you’re almost there)
9
Sand your Pieces
- Once the carving is done, remove the pieces from the machine and sand them to avoid splinters.
10
Assembling
- It’s finally time to put the pieces together!
11
You're done!
- Enjoy your New Knock-Down Stool and don’t forget to watch the Video! ;)
