Ivy Window Panel
5 opens
2 copies
411 downloads 1 comment
Teams  Design
Teams Design
Let design climb your windows with this translucent plastic ivy pattern! The repeatable design allows you to add other panels to create a larger display. Use different colors for a personalized design that changes with the time of day, amount of light, and weather for an evolving experience.
40% Light Transmission White Acrylic Sheet
IVY_carvey_Production01.ai
Native CS Artwork
IVY_carvey_Production01.svg
Carvey File
Carvey Cutting Time
480 minutes
Using the link provided and your preferred color and/or material, cut the pattern using your Carvey.
Remove the finished cut panel from the Carvey and prepare to cut the main design out from the surrounding remaining frame.
Link
Remove Extra Material
Cut away extra material that is not wanted from the pattern.
Hang Panel(s) on Window
Use small suction cups or another hanging solution to attach the panels to your window. The natural light reflects through the translucent materials. Arrange the panels as you wish to create different displays!
The suction cups used here were purchased on amazon.com: 12 Tiny 7/8" Suction Cups
Jason Basquez
this project isnt available. it needs to be shared.
Jason Basquez
