Hand crank for the X-Carve Z-axis
96 opens
21 copies
623 downloads 1 comment
Marius Hornberger
Marius Hornberger
Germany
During testing the X-Carve I often ran into the problem that I wanted to carve another shape and needed to change the bit. But I always had to lift up the spindle with the software. SO I decided to make a little hand crank that goes on top of the Z-axis for lifting the spindle up manually.
Baltic Birch Plywood
hand crank template.svg
Watch the project on YouTube
2 minutes
I put together a video on my YouTube channel that shows everything.
Let the CNC do its work
Cut out the shape out of a material of your choice. I recommend birch plywood or the stuff I was using, which basically is birch plywood with a black resin coating. I chose it, because it’s black and the machine is black, so…you get it.
Adding the nut
I skipped the painting part, because it’s painting and not very interesting.
After painting put a nut in place.
Hammer in the nut
Just grab a hammer and pound the nut into place. You could also use a vice.
The knob
You can make the spinning knob in several ways. I made mine on my lathe, but a dowl with a hole through it, big enough for a screw, will do the job.
Done
Simply screw the hand crank back on top of the Z-axis and your done.
Brian Gidney
Awesome idea Marius thanks for sharing!
Brian Gidney
