Half size Cornhole set
687 opens
185 copies
Sam Alaimo
Sam Alaimo
Get the party started with this slightly smaller version of a classic Midwestern yard game.
Baltic Birch Plywood
Baltic Birch Plywood (×4)
18" × 24" × 1/4" Baltic Birch Plywood
$5.99
$5.99
Open the Easel File
Hit the “open in Easel” button and look at the workpieces.
Each workpiece needs to be cut twice (4 sheets total). This project was designed to fit on 4 18″ × 24″ sheets of 1/4" material.
Customize and cut the files
You can add a custom design to the different boards. I added icons from Easel.
Cut out the files.
Assembly the boards
Use wood glue and clamps to create the boxes. You can add a hinge to the feet so they can fold and over and stack up when stored away.
Watch this Easel Live to make your own from scratch
I made the project with the Box app In Easel. Watch this Easel live to see how to use the app.
