Hadron Ordbot Expansion and Update
Shawn Markham
Shawn Markham
Increase the Z by 50mm and Y travel by 100mm of my 3D printer. (200mm X, 300mm Y, 200mm Z)
I will also be update the electronics with a RAMBO Mini and a mini touch screen attached to Raspberry Pi for Octoprint.
MakerSlide - Black Anodize - 5M Tapped (×3)
Length: 1000mm - 2012 - 2019
Parts
Physical Structure
  • Aluminum Y Carriage Plate XL 300×200mm
  • T8 L300mm 8mm Lead 4 Start Lead Screw and Nut for 3D Printer Z Axis
  • 3 sections of MakerSlide Length: 1000mm
Controller
  • UltiMachine Mini-Rambo 1.3 × 1 Optical Endstop Switch DIY Kits w/ Wire Harness
Octoprint
  • Raspberry Pi 3 – Model B – ARMv8 with 1G RAM
  • Castle Creations CC BEC 10A 6S Switching Regulator
  • PiTFT Plus 480×320 3.5" TFT+Touchscreen for Raspberry Pi
  • Raspberry Pi NoIR Camera Board v2 – 8 Megapixels
  • Adafruit Raspberry Pi Camera Board Case with 1/4" Tripod Mount
  • Flex Cable for Raspberry Pi Camera – 1 meter
Hotend and Extruder
  • E3D All-metal v6 HotEnd Full Kit – 1.75mm Universal (Direct) (12v)
  • E3D Titan Universal Extruder
  • Geeetech 3DTouch auto bed leveling sensor for 3D printer
Heated Bed
  • RepRap Champion 3D Printer MK2A 300×200mm XL Size Heated Bed
  • Borosulicate Glass, Hardware, Wiring, Thermistor Kit
  • GT2 5 Meters Timing Belt + 2Pcs 5mm 20Teeth Timing Pulley Wheel
