The author’s moral rights;
Rich,
Thank you for sharing this design! Do you think it has to be birch plywood? I have MDF on hand - do you think that would work? I plan on using this as an end table. Also, about how long did it take you to cut everything for this?
Shannon Humphryes
Rich awesome Work... im also wondering about MDF whats your thoughts
Mike Goodrum
Mdf is to weak for all these joints. Also the entire plan is on here free so no need to buy it. Just a thanks and a picture of your stool would be awesome. Thanks all.
Rich Litton
Mr Rich once you’ve put it all together, what’s the overall height of the stool?
Daniel Nathan Gallup
The height is the same as the uprights.
Rich Litton
Michael Petisco
Rich Litton
Michael Hagle
Michael Hagle
Shannon Humphryes
Mike Goodrum
Rich Litton
Rich Litton
Rich Litton
Stephen Robinson
Teresa Steadman
Rich Litton
