Gamer Tag cutout
20 opens
10 copies
400 downloads 0 comments
WorkinWoods
WorkinWoods
Hello everyone this is a small project that I made of a small Gamer Tag finish to your desired liking be sure to let me know how you did it
Birch Plywood
Birch Plywood
Image of Gamer tag
small skull gear.nc
Easel Gcode of Gamer tag
small skull gear_detail.nc
Easel created Roughing Gcode .125" bit
small skull gear_roughing.nc
Easel created Detail Gcode .0625" bit
Setup and Carve
Easel setup:
Roughing Pass:
Saftey Height: .150"
Step over: 40%
Feedrate: 45 in/min
Depth of cut per pass: .0625"
Depth of total cut: .050"
material thickness: .25"
Material type: Birch Plywood
Bit Size: .125"
Detail Pass:
Step over: 40%
Feedrate: 25 in/min
Depth of cut per pass: .03125"
Bit Size: .0625"
It might save a little time if you do a roughing pass with an .125" bit and then go back and do a detail pass with a .0625" bit I will provide a roughing Gcode file and Detail Gcode file above make sure and have this feature turned on in easel by asking for access in this thread on the Inventables forum with the link below
https://discuss.inventables.com/t/two-stage-cuts/869/582
