Flip milling involves carving both sides of your material. This Easel Live class shares tips for setting up your Easel file for flip milling. It also includes a jig to align your material easier.
We teach these techniques while making an engraved box with a v-bit in Easel Pro!
The author’s moral rights;
Michael, you can find the Flip Milling Bracket in the final workpiece of the Easel project. Click the 'open in Easel' button (above) or "use this link.":https://easel.inventables.com/projects/QfhCXCqYn6v9SfaM9bMc2g
Mo Stych
The screw can be any length, provided it is an M5 screw (the same as the X-Carve clamps). Hope this helps!
Mo Stych
The bracket does not support the post Nov 21 x carve waste board holes. By my calculations it would be 3.125 in center to center on the hole because the holes are 3.375 inches apart from outer edge to outer edge then minus 1/2 of the .225 twice for both holes plus or minus .10 of an inch
Jason F. Posey
I ran out of space above, but thank you for a wonderful video.
You are doing great things!
Some one please check behind me and comment if I am correct. I was asking not telling ?
Jason F. Posey
Rick Frantz
Michael Anthony Sullivan
Mo Stych
Raymond Fuller
Mo Stych
Jason F. Posey
Jason F. Posey
