Mon - Fri: 9am - 5pm CT
Closed Sunday 8/7
Engraved Neon Plant Stand
57 opens
15 copies
2 comments
Cultivate Studios
Cultivate Studios
Chicago, Illinois
Display your plants in style! Let your personality shine through by customizing the etched pattern and choosing the perfect colors to complement your home.
Fluorescent Green Acrylic Sheet
Optional: Customize your engraving design
You can either use the provided engraving design or watch this video to learn how to create your own design in Easel.
If you are creating your own design, start from this blank template.
Measure your material
Measure the exact size and thickness of your material. The thickness of acrylic is inconsistent from piece to piece, so this is an important step.
Secure the Material
Using double stick tape, securely attach your material to the wasteboard.
Engrave the planter
11 minutes
Set the size and thickness of your material.
The provided design is located here, or use your custom engraving design in this step.
Use an engraving bit with the cut depth set to .01” and the 1/32 2FL Fish Tail bit. Carve the design.
Leave the material secured on the wasteboard for the next step.
Adjust Connector Slots
2 minutes
Open this Easel file for the shape outlines.
The small rectangles (which are the connector slots) are set to a width of .25”. If your material is thinner than that (for example, .22”), the rectangle width should be changed to that measurement as well (or .003” smaller for a tighter fit). The width can be changed in the “shape” palette, make sure the center position is selected and that the lock next to width and hight is unlocked. Then type in the correct value.
Cut out the pieces
21 minutes
Set the Z-value and cut depth to the thickness of your material.
Carve the planter pieces file from the previous step using a 1/8th bit. The 1FL straight bit (black ring) works well for acrylic.
Assemble
Slide the 2 pieces together at the connection slots.
Bob Jewell
The links in sections 4,5 and 6 have not been shared publicly.
Bob Jewell
Cultivate Studios
Whoops! Sorry about that. Try again Bob.
Cultivate Studios
