Obviously these earrings need to be as thin as possible and to get the laminated (Sandwitched) look I was after I needed the three pieces of stock to be about 1/16". To accomplish this I started off by resawing the stock to slightly less then 1/4". NOTE: I ran each piece over the jointer before resawing so I had one side already squared up, I ran this side of the stock against the bandsaw fence.
I have a youtube tutorial where I go through all these steps showing you how I made these earrings. Check it out and let me know what you think!
I used a foam paint roller to spread a thin layer of glue on the boards and layered them in the pattern I was after. I glued three laminations using these patterns; Padauk, Maple, Padauk: Maple, Padauk, Maple: Walnut, Maple, Walnut. I then clamped the three separate laminations in parallel clamps and let them dry overnight.
I needed a small hold in the top of the heart to pass a section of wire through to hang the earrings. I marked this hole using a awl to prevent the bit from traveling and then drilled slowly and with high RPM using a 1/16" drill bit.
When the appropriate holes were drilled I finished the hearts with several coats of spray lacquer. (Probably 8-10 light coats per side.)
To hang the earrings I used some sections of 20awg wire, bent a small eye that will go inside the heart and hold it in place. I slid this wire though a small heart and then through a big one creating a heart within a heart, then clipped off the excess wire and carefully bent another eye at the top. This top eye attaches to the earring loop in addition to holding the hearts together.
Justin Haugens
DIYTyler
Cameron Asztalos
