Diresta Inspired Shop Stool
97 opens
9 copies
4 comments
Jeremiah Brown
Jeremiah Brown
Temple, US
This is my version of a shop stool using about a half sheet of 3/4" plywood. 24" tall x 12" wide legs 14" round top with a 6" decorative spacer at the base. I base all parts with no tabs since I use the Painters Tape and CA glue method of clamping.
The Different parts of the stool are here:
The right leg is here:
Link# Right Leg
The Center Brace is here:
Link# Center Brace
The Top Cross Grove is here
Link# Top Cross Grove
The top profile is here:
Link# Top Pofile
Jeremiah Brown
The right leg is here : http://easel.inventables.com/projects/GXoNgVLWs-L_8GTU350RCw#
Jeremiah Brown
Jeremiah Brown
The Center Brace is here : http://easel.inventables.com/projects/Jbr9j76POMwNL94-3r4I7g#
Jeremiah Brown
Jeremiah Brown
The Top is cut from the center as well as a cross groove on the bottom to slot onto the legs Cross Grove is here : http://easel.inventables.com/projects/wlLDxVYPHoYZfuhtQ-Rnsg#
Jeremiah Brown
Jeremiah Brown
The top profile was based on the center as well this is the profile - no tabs I use painters tape and CA glue to hold down all projects - profile here : http://easel.inventables.com/projects/DJCOX8LMa-A9LJMIAAie3Q#
Jeremiah Brown
