First we cut the corian parts for the base and stand of the planter. These can be done with either an 1/8th inch bit or by starting with a 1/4 bit to mill away the bulk of material and then refining with an 1/8th inch
Use this EASEL link
For this step you will want to flip the corian sheet over and align it to cut the reverse side of the circular puck part. This recess is to allow room for the joinery between the legs.
Use this EASEL link
These rings will make up the walls of the planter. A fishtail or square ended bit is best for this cut. This will allow the steps to turn out crisply.
Use this EASEL link
Jene Johnson
Jene Johnson
Paul Kaplan
aaaaaa
aaaaaa
Colby Hysten
