Cutout Birthday Name
anne gutzmer
anne gutzmer
A Pattern includes a cutout of a name – hearts included to tie fragile letter parts such as the dots of i’s.
Tabs are added to outside edges.
Steps – type name in Easel
duplicate
Use Offsetter App to make the background – full depth cut
slide under your original and set original to 0
Baltic Birch Plywood
8" × 12" × 1/4" Baltic Birch Plywood
Choose Font - Type Name
This is a simple pattern.
You type in a name
Duplicate the name
Set the original to zero.
make the cutout background
Take the duplicate and use the offsetter app to make an offset
combine the offset
combine the offset and set it to full depth
slide the offset in place
slide the offset behind the original
and “select all”
the center horizontal and vertical.
add support tabs
add support tabs to the outside edge.
Since you will be completely carving away around the letters,
add little support tabs to hold the work until complete.
I used rectangles 1/4 × 1/4 inch set to .001 depth cut.
