Mon - Fri: 9am - 5pm CT
Sun 12pm – 4pm CT
Custom Note Pads
593 opens
215 copies
8 comments
Kristin Smith
Kristin Smith
Fun notepads made with custom engraved names or themes and leather handles. All made from scraps laying around our workshop.
Birch Plywood
Birch Plywood
Gather Materials
In addition to the 8″×12″×1/2" plywood and a drill press listed in the Bill of Materials, you will need:
Materials:
1/2" thick stack of computer paper trimmed to 8 1/2"x 6 1/2"
(2) 1 1/2" Binding Posts 1/4" in diameter – I got mine from McMaster
(1) 10" strip of leather (anything between 1/2" and 1 1/2" wide should work)
Tools:
1/4" drill bit
sanding paper
Carve the project
Secure the piece of 8″×12″ plywood on the x-carve
Open the Easel Note Pad# file.
Using the rough size bit first (mine was set to a 2.55mm bit), carve the rough pass
Next, change out your bit to the size you need to complete any detail. For the “Ideas” design shown, I used a 1/32" bit. Be sure to change your speed and depth settings for the smaller bit so you don’t break anything :)
Sanding
Once you have removed your project from the X-carve, it’s time to sand. Flip it over and sand any residual (or tabs) from the back of the piece that may still be holding it together. I also sanded the top plate and the base to remove any sharp edges or splinters waiting to happen.
Note: You may want to leave the bottom edge on the back of the top plate as sharp as possible. This is the edge you will rip the paper against when tearing off notes from your pad. A nice sharp edge makes that much easier.
Drilling the paper holes
Align your top plate with with the top of your stack of sized paper on the drill press table. Using a 1/4" drill bit, drill straight down through the pre-carved hole and through the stack of paper. Being very careful not to lose the current alignment, move to the second hole and repeat.
Drill Leather Holes
2 minutes
Very carefully and slowly, use the 1/4" drill bit to drill one hole on either end of the leather piece.
Assembly
While you still have the paper and top plate holes aligned, insert the 1 1/2" binding posts through the top of the top plate and the paper. Then align your base plate holes from the underside of the paper and insert the remainder of the binding posts through the base plate. Then place the leather over the ends of the binding posts and insert the screws to hold it all together. Be sure to tighten your screws so it doesn’t come loose down the road.
Alexandre Amarante
Very good idea
Alexandre Amarante
David Young
You didn't share the file, is there a way you can share the file with us? Thank you!
David Young
Kristin Smith
I'm sorry David. I figured people would just use the Open in Easel button above. The file can be found at this link http://easel.inventables.com/projects/aN1GSYjxnEUGt12_v1FH8w
Kristin Smith
Tamara Smith-Hoyle
still not available thru this link. It says "not shared by the designer" thanks
Tamara Smith-Hoyle
Kristin Smith
So strange. It didn't save my "shared" status. Sorry about that. See if it works now, http://easel.inventables.com/projects/aN1GSYjxnEUGt12_v1FH8w.
Kristin Smith
Paulo Biha
Hi Kristin, your notepad is wonderful. Could you please share the file again? Your last link doesnt work. Thanks
Paulo Biha
Kristin Smith
I have renewed the URL once again. My business partner and I share files all the time. I'm not sure why this would be causing issues now. I just clicked on the "Open in Easel" button at the top of the project and it opened perfectly. Let me know if you have any problems now.
Kristin Smith
laura palmer
I CAN GET WITH NO PROBLEM, LOVELY PAD, THANKYOU
laura palmer
