Cubey 2
71 opens
14 copies
416 downloads 0 comments
David Bennett
David Bennett
Puzzle box from bruce viney, cubey2, adapted for cnc plans.
Bamboo Plywood
Bamboo Plywood
Bamboo Plywood
Bamboo Plywood
Thickness: 1/8 in, Plies: 5, Dimensions: 8 in × 12 in
$7.49
$7.49
http://homepage.ntlworld.com/bruce.viney/Cubey%202%20T-Plans.pdf
Cubey 2 T-Plans.pdf
Setup
Setup the main plan onto the 1/8 in plywood and cut it out. Make sure you clamp it down nicely.
Clean up the pieces.
Square all the corners and edges so everything fits together properly and run through the dry run in the pdf instructions to make sure the pieces fit together correctly.
Outside bits
Cut 6 × 2.5″×2.4″ squares for the outside of the box. Cut the offset windows into the box as shown in the cnc cutting plan.
Cut out six 3/4″ × 1/2" spacers from the 1/4" plywood.
