180 minutes
-Set up with a 1/16" Solid Carbide Fish Tail bit.
-Insert and secure a 8″ × 12″x .25" sheet of Corian material.
-Cut (3) passes using the associated .svg files
First pass – outer pattern
Second pass – pattern through cuts (this will take a couple hours)
Final pass – cut outline to release the part
Sand the edges smooth. If you’ve added tabs, remove them completely. Corian is very easy to sand so go easy. We used an old sheet of 150 grit and were able to quickly smooth out the edges with a block.
Frank Welte
Studio Murmur
brian saban
Studio Murmur
Mark Shuck
Scott Eaton
Scott Eaton
Ruth Egnater
Martin
Greg
