The Contrast House is an adaptation of the Berea Contrast House available for free from makeCNC.com. These files have been adapted and optimized for carving on the X-Carve.
This kit has been re-designed to be carve from 1/8th inch or 3mm material. It needs to be carved with a 1/8th inch or 3mm mill bit.
To get the assembly instructions, order for a free set of Berea Contrast House plans at MakeCNC
Plans and assembly instructions are delivered digitally after completing check out.
The other seven easel projects are available by following these links:
Casey kookla
Casey kookla
