second design, increased the caliper slot for a 8" caliper, added a slot for the stock spindle wrench and collet w/ adapter. plenty of bit storage, a pocket for misc. items and a slot for the hex driver.
I cut this out of cross linked polyethylene foam, using a 1/8" 2 flute upcut bit.
The author’s moral rights;
