Classic Chess Set
Samantha Alaimo
Samantha Alaimo
Chicago
Choose what kind of material and colors to make your classic chess board and pieces out of.
Bamboo Plywood
Bamboo Plywood
Thickness: 1/8 in - don't use, Plies: 5 - don't use, Dimensions: 12 in × 12 in - don't use 2
Black ABS 3D Printer Filament
Type: Filament, Diameter: 1.75 mm, Material: ABS, Color: Black, Shade: Black, Spool Weight: 1 kg, 3D Printer Compatibility: RepRap
White ABS 3D Printer Filament
Type: Filament, Diameter: 1.75 mm, Material: ABS, Color: White, Shade: White, Spool Weight: 1 kg, 3D Printer Compatibility: RepRap
CHESS_FULL_SET.stl
Chess pieces for 3D printing
12x12_chess_board.svg
Chess board for laser cutting
Laser cut the chess board
Focus the laser in the most upper left hand corner of your material. Raster engrave the chess board file onto your material. If using a 1/4 in material, or thiner, you can also vector cut the square board out of a bigger piece of material. If cutting on a 12 × 12 piece of material, or material thicker then 1/4 in, only run the raster engrave.
3D print the chess pieces
upload the .stl file into the software compatible with your machine. You have to run this job with the supports ON for it to print correctly.
marla latinakova
Great idea! Now I can finally have the Capablanca chessboard I've always dreamed of,
marla latinakova
Danny Tanner
Nice project. Can you tell me what size of the squares?
Danny Tanner
Danny Tanner
1.5 inch is my guess?
Danny Tanner
