Clamp Set Rack
365 opens
171 copies
1 comment
Jeff Williams
Jeff Williams
This is a storage block for the inventables clamp set for 3D carving. It was carved from a scrap piece of 2″ × 6″ × 12″ It also has a place for the Z probe and collet wrenches
Dan Caescu
I just tried to make this and failed big time on my first attempt. I used an 1/8 2 flute end mill. Everything was too small for all my clamping stuff. Did you use and 1/8” end mill bit? How long was it and do you know why if you used an 1/8” bit why mine would have made everything smaller?
Dan Caescu
