It is proposed to make a two cherry wooden bases, i carved out this bases in 3/4" thick cherry wood, this bases will hold two glasses (4″×6″) and in between the photo you want to put.
The design is so simple, that you can vary according to the photo you want to frame
The author’s moral rights;
Daniel Hirsch
