Mon - Fri: 9am - 5pm CT
Sunday: 12pm - 4pm CT
Support: 312-775-7009
Cheese Board with Knives
The Guru
The Guru
Monogramed cheese board with Knife. Pictures are from two different projects, one with walnut base and maple inlay, and one with maple base and purple heart inlay. Files should work fine with both, but inlay should probably be customized for the proper initials or whatever you are making.
Carbide Tip Upcut 2 Flute - 1/4 in Cutting x 1/4 in Shank
Cutting Diameter: 1/8 in, Shank Diameter: 1/8 in, Cutting Length: 1/4 in
Cherry Wood
Cherry Wood
6" × 12" × 1/8" Cherry Wood
$7.14
Hard Maple
Hard Maple
6" × 12" × 3/4" Hard Maple
6" × 12" × 3/4" Walnut
$11.43
$18.57
Route Bottom
90 minutes
Route bottom pocket using the bottom pocket file (b_025_pocket_feed60_and_fin45.nc). Requires 0.25" bit and a lot of patience. Chip removal is required.
Once complete, route the outline using t_outline_feed35_fin25.nc file.
Top Pocket
24 minutes
Route top inlay pocket using a 0.125 bit (t_inlay_m_pocket_feed35_fin25_no_ramp.nc).
Once complete, route outside border using t_outline_feed35_fin25.nc.
Top Inlay/Contour
14 minutes
Route top contour from nice hardwood using t_inlay_m_contour_feed35_fin25_no_ramp.nc. Make sure contour material is held down with double sided tape around the routing area. It will break free and destroy the inlay otherwise.
Once contour is cut, carefully place in pocket. Use spare 2×4 to fully seat by hammering from top, evenly across the inlay surface until inlay is flush with top.
Route magnets
4 minutes
Route pocket for magnets using b_pocket_magnets.nc.
Install magnets
Install magnets. Wood glue should work; let dry for 30-60 minutes before engaging magnets.
Drill and cut dowel
Tape top and bottom pieces together.
Drill 1/2" hole for dowel. Cut dowel to length (~2") and install. Glue dowel to top, let bottom slide freely.
Sand dowel flush with top and bottom.
Trim top and bottom
Using outline cut, trim top and bottom to size using jig saw or band saw.
Sand, Sand, Sand
Using a belt sander or table sander, sand edges smooth to outside line cut during pocketing.
Once sides are smooth and uniform, sand top and bottom. Start with 100 grit, then 150, then 220. Finish with hand sanding with 400 grit.
Steve Morgan
Where do you get the Knives?
Steve Morgan
The Guru
Hi Steve - from Aliexpress. Something like this: http://www.aliexpress.com/item/5Pcs-Colorful-Plastic-Handle-Cheese-Butter-Fork-Spreader-Stainless-Steel-Knives-Sets-Cutter-Kitchen-Cooking-Tools/32418137012.html
The Guru
