Cathedral Internet Radio
45 opens
8 copies
655 downloads 1 comment
Nick Brewer
Nick Brewer
I’ve always loved the look of old cathedral radios and I decided to build my own and have it powered by a raspberry pi.
It has three modes
- Internet Radio
- Bluetooth In
- Aux Input
cathedralRIBS.svg
KnobsFiles.123dx
cathedralBACK.svg
cathedralV4.svg
Bill of Materials
- Front/Back panel – 1/8" Walnut
- Ribs – 3/4" plywood
- Raspberry Pi A+
- 20W Stereo Amp (https://www.adafruit.com/product/1752)
- Bluetooth audio receiver (http://www.amazon.com/gp/product/B00PXC0CIK?psc=1&redirect=true&ref_=od_aui_detailpages00)
- 3P3T Switch (http://www.amazon.com/gp/product/B00K855OZI?psc=1&redirect=true&ref_=od_aui_detailpages00)
- Laptop speakers
- 2.2" TFT Display
- 10k potentiometer
- 5 way navigation switch
Cathedral Build
- Cut out one cathedral rib and use that as a template with a hand router. (I found this cut down on the cnc time significantly)
- Cut out the front panel (I used several different sized bits for this)
- Cut out the back panel
- Glue the ribs together to give it about 5" of depth
- Sand/stain the entire thing
Electronics Build
This is really going to depend on how you set up your system.
The biggest tip I can give is that I used the 3 pole switch this way… each audio source is broken into Left/Right/Ground. These all go into the switch, so each position represents one source. All the outputs are fed through the switch to the amp.
Programming
I used NOOBS to set the pi up initially because it’s super easy.
This will take some python/programming knowledge and feel free to pick through my code to help figure it out.
- Install MPD on the Pi (https://learn.adafruit.com/raspberry-pi-radio-player-with-touchscreen/installing-the-music-player-daemon)
- Instructions on getting the TFT LCD screen to work (http://marcosgildavid.blogspot.com/2014/02/getting-ili9341-spi-screen-working-on.html)
- The python script can be found on my github page along with all the wiring pinouts (https://github.com/nickbrewer/Radio)
- Launch the script on startup (http://www.instructables.com/id/Raspberry-Pi-Launch-Python-script-on-startup/)
- Edit the mpd playlist for your own stations and change the images
Finished!
It’s not an incredibly difficult build, but is a great way to help hone your making skills.
vlada
This project looks great. Love it.
vlada
