Matt Haas Enola, PA
Carve small dots to find the home position for multiple carving sessions and use the lines on the X-CARVE waste-board to keep everything straight. Doing so will make for a near-seamless carve.
Just a few simple dots… that you will eventually remove… is all you need to make several carving sessions produce perfectly aligned objects.
